Hi @dududuji
I would extract the properties of the faces in one of these two ways. You can find the proper name of other properties by double-clicking on the ‘HB Face Energy Attributes’ list.
Thank you very much for your reply! I’m doing a light simulation using radiance, and I’d like to know the reflectance of the material specular reflectance. The one you sent me seems to be about energy consumption construction, may I ask how to check the parameters related to light, such as specular reflectance?
You can just write instead:
property = faces.properties.radiance.modifier.specularity
You can replace specularity with other properties you are interested in, such as average_reflectance, r_reflectance , g_reflectance , b_reflectance, and roughness.
Thank you very much for your help!
