Recently, I’m trying to connect Gambit and Fluent with grasshopper to run CFD simulation. I learned much from Ladybug&Honeybee codes. Now I wanted to write a batch file to call the simulation software as you do in the “runDaylightAnalysis” or “runEnergySimulation” component. But I can not fully understand your codes.
Below is my code, which I imitate what you write. I think it still needs to be modified. Gambit is an execute programming, and I want to use it to run .jou file. I don’t know why two “fullPath” are needed.
It sounds like you are working on some cool stuff. The content that goes in the batchStr is a set of input parameters that are needed to run the specific program that you are calling from the command line. I would first try running the Gambit exe from a command window like so:
Once you figure out the specific parameters that need to be passed to Gambit to get it to run, you should be able to write a batch string that is simply a list of these parameters. Here’s another example of a component writing a batchStr for the new insect that I am working on (also derived from Mostapha’s examples):
Thanks a lot for your information. They are very useful for me. I will look into them carefully and try to modify my codes. Maybe we will have further discussion. I hope I can success and then share my work with you. Your work give me many inspiration. Thanks again.
create a model file in the COMSOL Multiphysics GUI, also known as the COMSOL Desktop. Since we’re going over how to use a new functionality, the smaller and less detailed the model, the bette
