Hello. I have the latest version of Ladybug honeybee LB1.2.0. I am trying to customize HVAC system. I tested 2 different systems PTAC and (VAV reheat). The first system PTAC works properly just it has one problem when I am trying to make the heating season schedule, fan electric consumption result shows values during summer. How can I design a fan coil to work only for heating season?
2nd HVAC, when I run it with VAV, it has a fatal error, ‘1. Solution exception: ** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.’ . Could you please check my file?
https://drive.google.com/file/d/1KN9gN4_Aubu0q2uTMFpn9AKECHM1QG-G/view?usp=sharing
Thanks
Regards
Yasaman
