Hello everyone,
I would like to ask if it is possible to apply a schedule to the temperature settings of the air conditioning system so that it can set 24 different temperature values in 24 hours a day?
[HB Apply Setpoint Values] can only set a single constant temperature value.
Yes, absolutely. Most of the programs that ship with Honeybee use setpoint schedules that have daytime setpoints that are different than nighttime setbacks. In order to create your own setpoint schedule, you’ll have to use one of the four schedule constructing components like the HB Weekly Schedule. The schedule values will be temperatures in Celsius and you should use Temperature for the _type_limit_. Then, you can assign the setpoint schedule to your Rooms using the HB Apply Room Schedules component.
