Hi @MingboPeng.
I still have a problem with the new update for HVAC in Ladybug tools, the detailed HVAC. When I connect the HW use equipment, I wonder if the boiler system does not write in the OS file. But when I unplug it, the model is written correctly. I would be thankful if you could check it.
HW test.gh (57.3 KB)
Hi @ehsan.anvary, thanks for reporting this issue. It is indeed a rear bug, but not really related to the WaterUseEquipment specifically. I am about to push a fix and you should be able to download a new Ironbug installer in an hour. Please let me know if you have any questions.
