I cant find "set the view" in LB for GH
dear Forum,
in getting familiar with the wonders of LB I tried to replicate:
Unfortunately I cant find the “set the view” component
is this discontinued? Would I need to install early LB version (0.0.54) or use a GH alternative approach (I tried Horster, but got a bit lost there) ?
Any hints would be much appreciated!
Cornelis
Sorry for the very late response here, @CvdK78 , but this component was just ported over to LBT:
You can get it now with the LB Versioner and it will be in the LBT 1.8 release that will be happening soon.
Hi @chris. Thanks for this.
FYI: The hints of some of the inputs are wrong (look_around, lens_len). I noticed that the Args in the component don’t fit the inputs.
Thanks, @AbrahamYezioro .
I realized the same thing as I was ruminating on the work day last night. It’s good to know that we have you here as another line of defense when I don’t happen to be thinking about Grasshopper components before I fall asleep.
I just pushed some corrected descriptions here:
Hi @chris,
Thanks.
FYI, for some reason the descriptions are not there yet after the LB Versioner update.
Hey @AbrahamYezioro . Yea, there was a hiccup in the CI that prevented it from deploying. I just triggered another release so it should now be available with the LB Versioner.
