I have visualisation problem for my sun analysis on my geometry which imported from Revit
I have imported a Revit geometry via FBX formed, then imported another FBX file for shading blocks. But when I try to set up my model, the visual of the model is getting complicated with red lines as in the picture. What should I do about it?
Maybe you should purge rhino model firstly.And make sure that unit set is Meter.
