- I hope someone can help
Is it necessary to upgrade the EnergyPlus plug-in to fix this problem? - The whole simulation process is shown in the figure above
The problems shown are as follows
- The simulation has not run correctly because of this severe error:
2.* Severe ** Line: 1544 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line. - The simulation has not run correctly because of this severe error:
4.* Severe ** ~~~ 9.3664045333862305; - The simulation has not run correctly because of this severe error:
6.* Severe ** Line: 1545 Index: 19 - “9.3664045333862305” is not a valid Object Type. - The simulation has not run correctly because of this severe error:
8.* Severe ** [RunPeriod][customRun][day_of_week_for_start_day] - “Yes” - Failed to match against any enum values.
