- The EnergyPlus battery appears orange when running energy simulation
- Want to know what reason causes have the person that know to tell me
The problems shown are as follows
- The simulation has not run correctly because of this severe error:
** Severe ** Line: 1544 Index: 2 - Error parsing “FenestrationSurface:Detailed”. Error in following line. - The simulation has not run correctly because of this severe error:
** Severe ** ~~~ 9.3664045333862305; - The simulation has not run correctly because of this severe error:
** Severe ** Line: 1545 Index: 19 - “9.3664045333862305” is not a valid Object Type. - The simulation has not run correctly because of this severe error:
** Severe ** [RunPeriod][customRun][day_of_week_for_start_day] - “Yes” - Failed to match against any enum values. - The simulation has not run correctly because of this severe error:
** Severe ** [RunPeriod][customRun][end_day_of_month] - Value type “string” for input “UseWeatherFile” not permitted by ‘type’ constraint. - The simulation has not run correctly because of this severe error:
** Severe ** [RunPeriod][customRun][end_month] - “31” - Expected number less than or equal to 12.000000 - The simulation has not run correctly because of this severe error:
** Severe ** [RunPeriod][customRun][end_year] - Value type “string” for input “Yes” not permitted by ‘type’ constraint. - The simulation has not run correctly because of this severe error:
** Severe ** [json.exception.type_error.302] type must be string, but is null
