Im facing this error - “screenshots attached” while opening the idf file in energyplus idf editor that is being generated after performing energy simulations with HB energy (ladybug tools 1.2)
This error only occurs when I use a DOAS type system but not in Ideal air loads.
I tried using the sample Honeybee energy script, changing the IAL to a DOAS+VRF to understand if my original model has issues, but the error persits even in the sample script.
I tried to read about this issue on Unmet hours (How do I fix IDF Editor "too many fields" error? - Unmet Hours) but I havent made drastic changes with my model. Just changed the system from IAL to a DOAS+VRF everything else is default. Also the energy plus is what is downloaded with Openstudio 3.1.0. Anyone has any clue what’s going wrong in the first place? I usually use EPlaunch and Openstudio to make changes in my HVAC systems but never faced this issue before.
Im also uploading the gh sample file in which I just changed the HVAC system if anyone can help by looking at the script. Thanks in advancefull_building_energy_model_VRF.gh (432.5 KB)
