"If Envimet is not in default unit 'C:' connect the installation folder" error
Hello everyone,
I’ve been working in a simple exercise, just to get to know how envimet works with grasshopper.
Everything seems ok, the components do show any warning messages and when I try to run the simulation, at first, it works, but after a while, when the main module of envimet is started, I get the message: “If Envimet is not in default unit ‘C:’ connect the installation folder.” Then the simulation stops, the window shows the message “Press any key to continue”, and once I do the window just closes.
The same message appears when I connect the Full Forcing settings component to the component where the simulation settings are established.
I don’t understand. Envimet IS in default unit ‘C:’. Because of these errors I even tried to use the Installation folder component with the directory to where envimet is (C:\ENVImet445) but it doesn’t really make any difference. Does anyone know what problem is this and how can I fix it?
Thank you,
Hello, have you solved this problem? I also encountered the same problem and don’t know how to deal with it.
FYI, @AntonelloDiNunzio has released a new plugin called Morpho, which is specifically devoted to writing and simulating ENVI-MET files from Grasshopper:
So I would recommend using that since dragonfly-legacy is deprecated at this point.
Hi
I have the same problem but it is while I am useing morpho. I have an average size model. The simulation starts running at first and evaluate flow calculation completely but after that the error or message occures:
[“If Envimet is not in default unit ‘C:’ connect the installation folder” error]
@chris
Could you find any solution for this error? I have the same issue
@AntonelloDiNunzio
@chris
@wizard
Hi, I’m using Morpho and I get the same error, do you know how to fix it?
@chris
@AntonelloDiNunzio
Could you fix the error?
Hey did anyone ever solve this error?
Cheers,
Ollie
Hey Chris i’ve also been getting this error with morpho. Has this ever been solved??
