Import from Revit to Rhino to make daylight analysis
I’m using Rhino.inside.Revit to export my Revit building to Rhino.
I need to make a proper setup of the model in the grasshopper to be able to do a daylight simulation. How is this done most easily, and are there any guides to this?
I really hope that some of you are able to help me out.
Here is a sample .gh file for performing an annual daylight analysis with Honeybee.
I might recommend using the Pollination Revit plugin to get a Honeybee model out of Revit since there’s usually a lot of manual work involved in getting a clean model with a Rhino.inside.Revit workflow.
