Oh! I found it in the previous answers! Sorry I asked.
Hi Noora,
itās still another problems, when u try to export from Archicad. I use Spider (Ladybug tool) to check and visualise the xml building, but sometimes it doensānt export the whole building⦠for example it miss overhings sometimes it miss some walls and roofs ā¦
Any suggestion itās welcome.
Merci beaucoup.
Thank u
Hi Aziz,
Yes, I see⦠I exported ArchiCAD to xml and I miss windows.
Iām new in ladybug and honeybee, Iād like to do daylight analysis and I wonder whatās the best way to work with Archicad files?
I tried AC-GH live connection, but the problem is that it is very difficult to choose openings (windows and doors). You can choose the surface of walls, roof, floor, etc. but not the openings!
Iāve also tried to export Archicad to rhino, but it comes with the wall thicknesses, and it is quite time consuming to clean the file, choose the right surfaces, etc⦠especially in complex models.
Does anyone have any suggestions on how to work with acrchiad files?
@Aziz.BOUKARA and @Noora you should post the issues with Spider on GitHub or tag @TheoA so he will be aware of them and help you to fix it.
In any viewer everything is OK, except Honeybee.
TheoA
Can i send u a ArchiCad file de try ?
Cause itās doenāt work fineā¦
@TheoA I have the same problem. I can see the windows in the viewer, but not in Honeybee
The problem is only when using ArchiCad file, but if using REVIT to Gbxml, the translation is wellā¦
Hello, I have exactly the same error with OpenStudio.OpenStudioGBXMLPINVOKE
I just updated Openstudio to recent versionā¦
Solved by downgrading Openstudio from 3.0 to 2.5
Maybe that is a silly answer, but have you tried to āshowā the last component? In screenshot it is dark grey which suggests it being āhiddenā
