Hi, @chris. First of all, thank you for your many solutions. I have solved many problems through your solutions in this forum.
But there is error in Importing IDF File.
I’ve tried to find a lot of solutions, but I can’t, so I’m asking questions
I want to import DOE reference buildings, so i try this way : How to Open the DoE Commercial Reference Buildings in Ladybug Tools - #4 by chris
It can import DOE reference buildings. But there is problem that there is no windows.
So i try to import IDF File directly using HB load gbXML OSM IDF.
I use Rhino 7, Ladybug-1.6.0, EnergyPlus-22.1
How can i solve this problem?
