All,
I cannot import my schedules in IDF format, despite doing the right thing (I think).
I have put my schedules in a IDF file (schedule.idf), in the right folder, which is:
C:\Users\USERNAME\AppData\Roaming\ladybug_tools\standards\schedules
Restart Rhino+GH, even reinstall Ladybug Tools, all do not help.
I keep having the following message:
Runtime error (ValueErrorException): "User Library Constant" was not found in the schedule library.
Traceback:
line 41, in schedule_by_identifier, "C:\Program Files\ladybug_tools\python\Lib\site-packages\honeybee_energy\lib\schedules.py"
line 105, in schedule_object, "<string>"
line 191, in script
Note: importing constructions/ materials works fine. I even tried to include the schedule in the construction file, but still it does not work.
The test schedule that I use is the following:
Schedule:Compact,
User Library Constant, !- Name
on/off, !- Schedule Type Limits Name
Through: 12/31, !- Field 1
For: AllDays, !- Field 2
Until: 24:00, 1.0; !- Field 3
Is it possible that LBT does not like compact schedule? I swear that the previous versions could handle compact schedules.
I use Rhino 7, LBT 1.8.
Any help would be appreciated. Thanks.
