Hi!
I am trying to import 3D geometries into Rhinoceros in .dwg format. They appear in the canvas as Block instances. I have tried several things:
- Explode the block instance into mesh -> mesh to nurb --> and then i get polysurfaces
- Explode the block instance into mesh -> mesh to nurb --> and then i get polysurfaces -> explode to surfaces
- Exploed the block instance into mesh
- Explode the block instance into mesh -> mesh to nurb -> mergeAllfaces.
My problem is always the same. When i open GH and i use, for instance, Geometry pipeline sometimes is ok. Mostly working with polysurfaces. But when i try to create HBSurfaces it just crashes.
My question is, what would be the best way to import geometries in Rhino so it is easy to handle the surface in GH (probably dwg is not the best) how/what could i export from revit?. Could it be also a problem of memory? If i explode the blocks into surfaces can be up to 100k surfaces in total (if i merge them it reduces the number drastically).
Is there a way or format to make this simpler?
What is your experience in importing to Rhino for using into GH?
Thanks a lot!
Ramón
