Hello, I am stuck trying to import the glass panel itself (as part of a curtain wall system) into Grasshopper/Honey Bee so it can be calculated as part as of a Therm model. I am asking what is the best way to import the glass panel into the model so it can be processed properly in Therm.
Hi@pdillon3 You should refer to @chris therm example file.
http://hydrashare.github.io/hydra/viewer?owner=chriswmackey&fork=hydra_2&id=THERM_Window_Frame_Construction
