Hi all, Honeybee 0.0.65, component “Honeybee_Masses2Zones”
- Solution exception:index out of range: 1
Any solutions? Have tried multiple geometries (closed breps), same issue.
Hi @smyliemeg,
You added a building programm index to a zone. You have to select a ZoneProgram.
(see image below)
Hi @smyliemeg,
If what @Erikbeeren recommended is not the case then please share a simplified version of your gh file with necessary geometries internalized.
