Ertunc
1
Hello all,
I’ve been trying to test the file “Microclimate_Map_-_Simple” from Hydra But indoor colors are the same…
But the result that I get is different. Is there any ideas on why I’m facing such an issue?
You could see the image for to compare.
This is how it looks on my computer.
Ertunç
chris
2
Perhaps you’re visualizing a different hour of the day? Or maybe you’re using a different EPW file.
Ertunc
3
Hello Chris,
Thank you for your message. I haven’t changed anything from the example file.
When I change the .epw file I get a different result but with the same issue. You can see it below:
Also attaching the file that I’m testing out.Microclimate_Map_-_Simple_to forum.gh (652.1 KB)
Ertunç
