Hi everyone
I’m going to model an indoor pool, I used one of the files in the forum
But I get this error "The simulation has not run correctly because of this severe error:
** Severe ** Plant Component SwimmingPool:Indoor called “MYSWIMMINGPOOL” was not found on any plant loops.
I would be grateful for any help to fix this error.
qadaki-3.gh (924.7 KB)
Hey @ilkin ,
Debugging specific EnergyPlus issues is more something for the unmethours.com forum than this forum. But the right way to do this with Ladybug Tools is using additional strings or an OpenStudio Measure.
Which method are you using here?
Hi @chris
thank you for your answer,
I used ironbug for detailing the plant loop and additional strings.
I have specified the name of the planet loop using ironbug components. After running the simulation, which goes to the stage of creating the Energy Plus “IDF” file and ends with that error, I check the Energy Plus file with the IDF editor., there is a specified plant name, but in the error, I get the message " Plant Component SwimmingPool:Indoor called “MYSWIMMINGPOOL” was not found on any plant loops."
