Hi everyone,
I’m currently running building energy simulations across all 19 ASHRAE climate zones using Ladybug Tools in Grasshopper. For each climate zone, I’m using the software’s built-in default constructions that correspond to that specific zone. Apart from the construction sets and the EPW weather files, every other input is identical – same geometry, internal loads, schedules, HB Ideal Air settings, etc.
The simulations for most climate zones behave as expected: the HB Ideal Air system is able to keep the indoor air temperature within the cooling setpoint range. However, I’m seeing a very strange result that occurs only in Climate Zone 7. I’ve tested this with three different city EPW files from that zone, and the pattern is consistent:
- Overall energy consumption is very low.
- During summer, the indoor air temperature is roughly 10°C higher than the outdoor air temperature, and about 16°C above the cooling setpoint.
- In all other climate zones, the indoor temperature stays comfortably within the setpoint range.
This doesn’t make sense to me. It looks like the cooling system is barely working, yet the indoor temperature is far above the setpoint. Could this be caused by the default constructions for Climate Zone 7? Or maybe an interaction between the very low outdoor temperatures in that zone and the sizing/control logic of the HB Ideal Air system? Has anyone encountered something similar or have any idea what might cause such severe overheating only in this one climate zone?
Any help or suggestions would be greatly appreciated. Thanks in advance!
