Inquiry about Honeybee transparent material
If I use Honeybee transparent material to make a prism. Do you think that Honeybee can understand the properties of the prism? so it can give me the spectrum light dispersed from the prism if I point direct sunlight on it.
Or there is another plugin for that sake?
I can get spectrum light from the prism using V-Ray in 3D Max, but I need to use Grasshopper to control more parameters.
Thank you…
Ahmad,
Very good question but unfortunately, Radiance really isn’t built to model light’s wave-like properties. It’s ray-tracing methods are exceptionally good at modeling illuminance in all of its forms but I don’t think there’s a rendering engine that currently exists that is able to model light refraction and diffraction in the way that you are describing. Sarith (one of the great Radiance gurus of our community) should confirm this but he already explained to me why light diffraction isn’t modeled with Radiance here:
https://github.com/mostaphaRoudsari/honeybee/issues/597
Extending his explanation, we can also conclude that it can’t model prisms and light refraction in the way that you describe.
-Chris
Hi Ahmad,
To add to what Chris mentioned, the spectral dispersion that we see with prisms require a full-spectrum continuous-band light source like daylight or light from an incandescent source. The x-axis in the image below are wavelengths.
Radiance considers only three channels for calculation (RGB) that mostly corresponds to the Trichomatic Theory. In short, as Chris said, Radiance (and therefore Honeybee) will not be able to replicate light dispersion through a prismatic material.
Sarith,
Purely out of curiosity, do you know of any rendering engines that are built to do full-spectrum analyses? I feel that every engine that I know uses Trichromatic Theory.
-Chris
Hi Chris and Sarith,
Thank you very much for your replies. As I told you before, V-ray for 3D MAX can simulate a full spectrum light analysis. Grasshopper as a parametric software can understand angles and equations which are unfortunately not applicable with 3D MAX.
3D MAX can only visualize the spectrum light with no specified angle or pre-scripting, just you can move the light manually till you get reflected and refracted light.
I think it would be really helpful to make a V-ray for Honeybee (RADIANCE), so we can use V-ray parametrically! Do you think it is possible to merge the two software?
Thanks
Ahmad
Hello old thread :slight_smile:
Im currenlty wanting to calculate possible Prism based sunlight Art installation in a Building.
Did something change since the opeining of the Topic here ? @sarith @chris
It seems like there are some python based tools that can handle complex refraction as stated in this paper:
Before i dive deep inside this i was curious to know the current state inside LB/HB-R.
Thanks :slight_smile:
Wow. Always good to get a reminder about how naive I was about Radiance simulation back in 2017.
I guess one update from then is that Radiance 6.0 has implemented a lot of new things to do hyper-spectral rendering with far more than 3 channels of light (I know @mikkel recently did a deep dive into it).
But my understanding is that there still isn’t any accounting for wave-like properties (diffraction or refraction) of light in these channels. So (I think) we’re still a long way from being able to do a Radiance simulation of light refracting through a prism or recreating the double slit experiment.
