Installing error
how to resolve the installing error——ascii’ codec can’t encode character . \u5C0F’ in position 13: ordinal
not in range (128)
Your username contains non-ASCII characters and the simulation engines that LBT uses don’t like this. The easiest way to solve it is to create a new username on your computer using only ASCII characters. Then, sign into that username and try to install from there.
Thank you very much for your guidance.
