I wanted to evaluate how internal thermal comfort changes if we change the way we are stacking bricks. Can this be done using Ladybug or Honeybee, or do I need to use some other plugin for it?
Whatever tutorials I have gone through have highlighted how to calculate the internal thermal comfort, but I am not sure how modifications to the building envelope would effect it. Here, the modification would refer to changes in brick morphology, changes in the stacking patterns, and the addition of air pockets in between bricks.
Hi @ayush
If this bricks are used as shading objects you can define them as shading objects.
will try this, thanks
