Hi guys, I’m using honeybee to perform an energy simulation. But I’ve got problem with ‘interzone surface areas-mismatch’. I’ve tried several times to redraw it and simplify my model but the problem keep showing. I have no idea either about which exact surface cause this problem or how to solve this. Can anyone kindly let me know how to find the problem surfaces?
@Erikbeeren the interesting thing is when I tried the method on another model, the error of surface area mismatch pop up again. I’ve attached this model could you kindly have a look please?
The grasshopper script is ok. It is more your geometrie wich is inaccurate.
See image below.
I usualy make blocks of every floor and import them with the Human plug in. In that way I have a better controle over the geometry.
In the example below you will find a simple model.basic template.3dm (47.7 KB) basic template.gh (576.8 KB)
Hi, @Erikbeeren
I’ve tried to delete the problem geometries and it works indeed. Thanks a lot for helping. The example files you uploaded are very help as well. Many thanks for sharing.
