In actual projects, a large space will not have only one coil placed in it, as this will make the model too large. Usually multiple fan coils will be placed in this area. However, when setting up the HVAC system in Ironbug, it does not allow multiple devices to be placed in one area. How can I solve this problem?
hi,@feifeifie
You can give the IB Zone EquipmentGroup component a try. This component enables you to input multiple Zone Equipment as a single “group” object into the thermal Zone.
best.
Zhengrong
ohh! It works! Thank you so much! ![]()
