Hello, I am trying to install ironbug. I already had it but suddenly when I was adding missing honeybee components, it is gone. Can you help me? When I trying to install again new version of Ironbug 1.9.8, first I’m unblocking and then I extract the zip file. After that, when I open installation file (Ironbug.Grasshopper.gha) it is warning me like ‘File type not supported by Rhinoceros’ . I am also adding warning image. Thank you from now.
Hi @yaseminklcoglu,
I would suggest you use the free Pollination Grasshopper plugin’s installer which installs both LBT and Ironbug components.
Hi -
I’m not sure what you mean by that. I can see a Pufferfish and a Pollination tab in your image.
-wim
