Ironbug_probe results
Hi @MingboPeng,
I have some problems with the Ironbug_probe Tool. I’m using:
  • Ironbug: V0.15
  • Openstudio 3.0.1
I have used the probe tool to obtain the air temperature at the return.
All the data for the air loop node “NODO_DOA” have “-999” value.
I’ve checked the node values in DView and the sqlite file.
All the other results of the analysis are fine.
Thank you for your great work!!
Hi @BestiaParda, you are looking for “System Node Temperature” for output variable, instead of “Setpoint Temperature”.
Thank you @MingboPeng, now works fine!
