Ironbug setpoint at outdoor high temperature 1 and 2
Hi, @MingboPeng
I model an AHU in ironbug, the supply temperature depends on outdoor air temperature. I use the component SPM_OAReset, compare with Openstudio, there is only one outdoor high temperature and one outdoor low temp, if I need to depend on two outdoor temp, how can I set it in IB? Thank you very much!
Hi @Congrui the current version doesn’t support it. I will work on this tomorrow.
Hi @MingboPeng Thank you very much.
Hi @Congrui
I finally got time to work on this. A new version of Ironbug will be released later tonight.
Hi @MingboPeng Thank you very much for your update, really appreciate it!
