Isoline curve lux values is not similar or close to the mesh values
hallo Forum,
I am trying since days but i am still not able to do it. Attached is the gh file. As you can see (after running), the values in the mesh ( lux values) doesn’t fit the isoline curves results; and in the isolines curves, when it reach the maximum value , it keeps posting the same value; and the lower values in the curve are not close to the ones in the mesh points.
( i am not able to fix it through average formula or interpolation…i am not sure actually how…)
What i want in the isoline curve is to show values for instance from 100 to 1000 Lux with a step of 100 Lux ( i.e : 100, 200, 300, …, 1000 ). On the other word, I want the scale to have from 100 to 1000 Lux with a step of 100 Lux.
any idea?
Thanks for your support!
nass.
Nass, It needs a little bit of extra math, otherwise it’s very similar to what you already have in the file.
120515_test_isolines_AY_MSR.gh (881 KB)
wow Mostapha, Thx a lot!
