hi all. I’m running an energy simulation for a room. the results that i get from a simulation for whole year are the same as simulation for period 8-15 hrs. i don’t know why it is happening! anyone have any idea what might be the problem?
The “error” was that you connected the created zone with the HB_Mass2Zone. This was cancelling the windows definitions and starting the zone creation from the beginning. There is no need, in your case for such connection. See attached.
Didn’t run it but i’m pretty sure you’ll see now the differences.
Thanks Abraham… I updated my HB & LB to the last version, but i get this error for running energy simulation: 1. Solution exception:global name ‘HBGenerators_’ is not defined as picture
I see that the zone program you set is OfficeBreakRoom. Being that i suppose there is no difference running the whole year hours or just 8 to 15. Those are probably the occupancy hours. Makes more sense to run just a few months than just some hours,
You only need to reinsert components if the inputs/outputs have changed in the updated version of the component.
For your analysis period question: EnergyPlus is not capable of modeling simulations that are shorter than a day. Therefore, the “hour” inputs on the analysisPeriod component do not have any effect on the Energy simulation component. The deeper reason for this is that the temperature and energy use during a given hour are dependent upon the temperature and energy use of the previous hours. So it is not accurate to run a simulation for the analysis period that you have set.
If you want to get data for just your occupied period in Grasshopper, you only need to post-process the results with the “Average Data” component:
