I am doing some daylight analysis and I am facing with this error: “Solution exception: ‘NonType’ object has no attribute ‘X’”. I searched but I couldn’t find a solution for my case. Would you please help me to solve it?
I attache the file as well.
Thanks.
Helia
Helia For send.gh (770.8 KB)
You should flatten and clean floor inputs that you used to generate test points. Based on the error message you are passing None values as input.
Thanks so much. It solved.
Now, I have another issue. I ran the analysis, the illuminance of the first and the second floors are different while the geometry of the floors are the same. I checked all the geometry, and I couldn’t find any reason for it. Did I miss anything?
Thanks.
Helia
Helia For send.gh (772.2 KB)
