Issue with HB Color Faces
I have recently been learning Grasshopper through the Ladybug Academy, and I am building a model using the updated Ladybug Tools version to test the Honeybee Color Faces component.
The model is of seven zones, where I have successfully computed the operating temperature. However, when I connect the required inputs to the Honeybee Color Faces component, I encounter an error that I am unable to understand – “1. Solution exception:ColorFace data collection does not have metadata associated with Surfaces.”.
I think you have connected a recipe of type Room to a colour display of type Face. Depending on what you need: to the Room results you associate a zone visualisation, to the Surface results you associate a face visualisation.
Bye-bye
Ah I see, it is working fine now. Thanks!
