Issue with the "Ladybug_Outdoor Solar Temperature Adjustor" component
Hi everyone,
I am doing some environmental analyses using Ladybug_Outdoor Solar Temperature Adjustor component.
but the problem is when I connect the _horizInfraredRad_ , the _diffuseHorizRad input goes blank.
I watched the Parametric Environmental Modeling with Ladybug tutorial series by @mostapha, and this didn’t happen.
Does anyone know what this is about?
Thanks in advance
@Nimafo , Hello
It is because the radiations values can be derived for solar adjusted temp from two ways ;
a) If you directly input direct normal radiations from epw file than you have to give diffuse horizontal radiations too from epw component:
b) If you use cumulative sky component, the solar adjusted temp component directly derives value from the sky patcesh that have been created from gen cumilstive sky (both direcrt and horizontal).
In the above pic mostapha have used the file from epw so horizontal radiation input is required from epw file.
Thank you @Asisnath :ok_hand:
