I have one question about one component of Ladybug.
I need to simulate a sunlight hours analysis over faces of buildings, but when a try to generate the contour mesh (Even just a facade) appears this error “The connected inputMesh is not planar and this component only works for planar meshes”
This component works with planar meshes only. Since you are interested in looking at sunlight hours on one Facade only. Only provide that facade as a surface in _geometry input and it should work.
