Dear all,
Here I conduct two ways modeling the specific windrose situation between 8 am to 3 pm, and also the dry bulb temperature is under 10 °C. One was using " annual Hourly data" changing the period between 8 am to 3 pm into boolean data, the other was using the “analysis period” defining the period.
The results were completely different. So I wonder figuring out the difference between these two methods. Thx for replying!
And also if I want to model a situation of radiation, requiring both under 25 °C and the analysis period should be between 8 am to 4 pm, which way the above showing can I use?
