Hey guys,
Issue1) grid-based analyses work based on CIE standard sky but is not working based on the climate-based sky and provides the following error:
- Solution exception:Failed to read the results!
fatal - cannot find function file “perezlum.cal”
Issue2) Annual daylight analyses is working properly when the epw file is connected to it but does not provide any result.
I have installed DAYSIM 4, Radiance 5.1 exactly as instructed and I am using Rhino 6. The only thing that is not installed is Python I guess.
Thx in advance!
