Issues with "Run OSM" and ScheduleFixedInterval (like in Ironbug workflows)
if there is FixedInterval schedules in HB Model, ironbug gives the error. My model for example, I have a 2-states shading with FixedInterval schedule, in the new osm model created by Ironbug, this csv file is not introduced.
  1. ** Severe ** [Schedule:File][FixedIntervalSchedule_5af1843a] - Missing required property ‘file_name’.
Just use the workaround that I posted, then, of editing that one line in the Model To OSM component. It looks like the way IronBug/OpenStudio SDK imports the OSM it gets rid of all dependencies on external files like CVS schedules.
Hi, just letting know that I get the same error:
I am trying to run an energy simulation with a lot of custom-defined schedules. All the schedules created with the HB Fixed Interval Schedule are causing the following error in the HB Run OSM component:
If I replace the FixedIntervalSchedules with other types of schedules the problem disappears. However, I would like to use FixedIntervalSchedules.
Here a screenshot of how I create my schedules:
And this is my simulation file Demand Simulation v2.gh (776.3 KB)
Editing the line in the Model To OSM components seems to resove the issue for now.
Thanks for clarifying this, @Josien . This wasn’t really related to the other topic this was originally posted on so I moved it here. I just pushed a fix to the “Run OSM” component, which makes sure that the file-based schedules are included in the simulation process:
You can get the fix with the “LB Versioner”. With the new “Run OSM” component, you shouldn’t have any issues with using ScheduleFixedInterval in your workflows.
