I run an energy simulation, and now I want to perform daylight simulations (daylight factor, point-in-time illuminance, sDA, and UDI). I want to ensure that the input of the HB Glass Modifier is consistent with my HB Window Construction.
For the HB Glass Modifier, what should I use as the input for the transmittance so that it matches my previously defined HB Window Construction? Should I deconstruct the window construction and use the visible transmittance (t_vis) as the input for the HB Glass Modifier, or is there a recommended way to keep the Radiance modifier consistent with the EnergyPlus construction?
Thank you in advance!
