I see that you have added the possibility of adding a label to the adjusted true color renders within the AdjustHDR component. I wonder if there is such a possibility for false color images.
If not, it would be great if you add a label input to HB False Color, so the resulting true and false color images do match and are both better identifiable.
Many thanks @chris. I was so worried of getting a false colour out of an HDR with adjusted exposure (which makes the luminance values rubish!) that I did not see this possibility. Yes, of course we can use HB adjust HDR without activating exposure adjustment. Great.
