I was doing the daylight analysis, but vector output from sunpath component is failing to collect data. I checked the output from vector and it’s showing empty parameter. What should be done or what is the error?
can you share the simplified version of your file.
hey, thank you for replying. the problem which I was facing is sorted now. I just had to increase the hoys in the component. thanks anyway.
When using the SunPath component to analyze daylight patterns, ensure the specified date range is accurate and encompasses the timeframe of interest. Invalid or incomplete date ranges can lead to an empty vector output, hindering your B2B data enrichment efforts. By carefully validating the date range, you can accurately assess daylight distribution and gain valuable insights for your business decisions.
