I am wandering if there is a way to control the order in which the sliders are animated with the Ladybug_fly component or some equivalent component.
I am trying to automate direct sunlight study captures using multiple sliders and want to avoid having to run the same simulation multiple times.
- The first slider controls the simulation so every time this slider changes, a new simulation is run (takes time).
- The two sliders beneath allow to capture multiple views (very quick).
So ideally, I would like the first slider to iterate first, then the one beneath and then the third one.
Thank you for your help!
