Hi, I am using Rhino 7, and the latest version of Ladybug. While all the other features are working fine, the environment tab from Ladybug is MISSING. As a result, I am not able to run simulations like Radiation analysis, etc. Any idea what could be the issue and how to resolve it?
Hi RP
You can check the compatibilty matrix:
You can try to use pollination grasshopper installer to install the version compatible.
