Hello!
I’m trying to use the Ladybug and Honeybee components in Hops. That way the simulation could run in hops so that Rhino would not have to freeze while the simulation is being run. To use the Ladybug and Honeybee components I need to initialize them with the components in the picture below. When I put these in the Hops canvas it breaks the Hops component.
Is there a way to initialize Honeybee and Ladybug without these components or can they be used in Hops in some other way?
Have anybody encountered this problem before or been trying to use Ladybug or Honeybee in Hops?
You can use the LadybugTools new version instead of the Legacy.
Thank you that worked great!
update: restart compute.geometry.exe locally and start fresh with Hops component and it works
