Hi everyone,
I have a biiigg problem :(( Normally, everything was fine. But, I downloaded the example files about energy analysis and tried them. After that, I couldn’t use this “ladybug import epw” component… When I use the epw file, it’s written “solution exception:pop off of empty list”. Does anyone have an idea??
Help me, pleaseee :(( If you help me I’II appreciate:(
Thankss…
Meryem…
I solved this problem. When I downloaded the new epw file and used this file, the component has started to work. I think the weather information is updated… I would like to inform you…If you meet such a problem, you can solve it this way.
Meryem…
