I would like to conduct a lighting energy simulation working with daylight. However there is no IES Luminaire component. I looked up in the internet, they say the component is not available for LBT 1.7.0. It was recommended to download legacy version. But legacy versions are not compatible with Rhino 7. I don’t know what to do.
Are there any suggestions?
In food 4 rhino website it says ladybug legacy works with rhino 6. Maybe it is my misunderstanding or couldn’t find the right source to download it.
Could you please provide the correct link to download and set ladybug legacy for rhino 7?
And also ladybug legacy has IES Lighting component, am I right?
Thank you in advance,
I honestly have no idea
if that one doesn’t work for some reason, I have the one with HB 0.0.65 and it works on my machine with R7
I understand. Thank you so much for your quick response. I hope It has missing components such as IES Lighting…
FYI, some capabilities of Legacy can fail in R7!! You don’t know what they are until you get into the situation.
