Can anyone help me to figure out why I cant seem to get the latest version of Ladybug tools downloaded? I tried from Pollination first, and was getting the ‘old’ text on the nodes that was causing crashes.
I realized I think the crashing was due to SentilelOne blocking the software, so I’ve fixed that issue.
I then downloaded the latest version of ladybug tools from Food4Rhino to see if this helps, but I still see ‘OLD’ text on the nodes as I try to use them.
I’m using Rhino 8
Hi @harperecraig ,
Then ‘Old’ tag appears when there is an error of some sort that happens during the LBT component’s module-import phase. So that means there is something mixed up or incorrect with the LBT library installation on your system.
You should definitely use Pollination’s installed, not the Food4Rhino. It’s not really possible to say what the error is, but I’d recommend trying to do a full remove and then re-install. I’d try doing a ‘find’ for all the ‘ladybug’ folders on your computer and removing them all. Boot Rhino and Grasshopper to ensure you fully removed all of it, and then try a reinstall from Pollination.
best of luck with it,
@edpmay
this worked! THanks so much for your help
