LadyBug Open EPW Component Reading Null
I am trying to create a Wind Rose diagram. When I download the epw file and run the component using the file it works fine. When I try to use the link from epwmap it reads “null”.
Pretty new to the program any advice would help, thank you.
Alex
You’re mixing Legacy and LBT 1.2.0 components. Just stick to using one version or the other.
I switched to all 0.0.66 components but the link is still reading null.
