I don’t know what you’re looking for here. But I see that everything is fine with your script. What you see is the percentage of comfortable time for the time period that you have provided which is a full year for all the locations of the bodies which in your case are 21.
Well, I’m glad to receive your reimbursement so soon. Thank you. The biggest problem is that the script doesn’t have any problems, but it works differently on other computers. On my computer, no matter how many analysis points he gets, you are the same. I don’t know what happened to it. And please note that I marked them in red and blue, which represent different points, but they get the same data. And last time, you saw 8.481735, and I thought it was the reason for the EPW file, but when I changed the weather file, I got 35.76484. I don’t know what happened. When I use other programs, there will be corresponding problems, such as figure 03 and figure 04. Their programs are derived from each other (I haven’t made any changes to the program, but the results are quite different from those on the website):
http://hydrashare.github.io/hydra/viewer?owner=chriswmackey&fork=hydra_2&id=Urban_Microclimate_-_Simple_Spatial_UTCI&slide=1&scale=1&offset=0,0
http://hydrashare.github.io/hydra/viewer?owner=mostaphaRoudsari&fork=hydra_1&id=locate_coffee_shops_based_on_outdoor_comfort&slide=2&scale=1&offset=0,0
I look forward to your reply. Thank you.
