Hi All…
this is basically a loft with 3 parallel circles, because rhino always define curves with start and end so ladybug does not think it’s a close surface?
Hi All…
You can address this issue either by using a smaller grid size or by meshing the input geometry before connecting it to the component. That gives you fill flexibility to generate a high quality mesh. Ladybug won’t remesh the input mesh.
thank you!. didn’t know ladybug only work with mesh
It works with both mesh and brep but if you feed a brep then it will mesh the brep based on the grid size.
